I'd suspect if he had independent controls he wouldn't really need helm steering. Just lock them all in 0* relative position & use the throttle & gear levers.
Of course, if it had helm steering it would be easier to move nearly directly abeam.
Are you sure that isn't just a bow wave & not a bow motor?
For "cruising" you can lock three of them straight ahead and steer with one. But for maneuvering I imagine it takes an "engineer" on each motor and lots of yelling....
Once that was worked out though, maneuverability should be awesome.
