BRASS vs BRONZE - REALLY A PROBLEM ????
36mainship36
WERE TALKING THRU HULLS. IF I USE CAST BRASS FITTINGS AND RED BRASS NIPPLES. WHAT WILL HAPPEN AND HOW LONG FOR IT TO HAPPEN ?? NATURALLY A SALT WATER ENVIROMENT. IF THERE WERE A GOOD SOURCE $$$$ FOR BRONZE FITTINGS, I WOULDN'T OF ASKED...
LOU R.
Lou...type in small case, will ya? Upper case is "shouting"...and we can all "hear" you fine! Thanks.
stay away from brass, it will fail sooner or later.
i had a brass nipple fail on my air con strainer, it failed a few months ago, strainer fell off as i was cleaning it... male/male bronze nipples are almost impossible to find...
dont take chances, use bronze.
and indeed, turn off the loud caps !
anything bought at a marine outlet should sell bronze fittings...that's all we stock and we're a fresh water dealer
I was considering using brass to add fittings to my bronze parts. The guys here convinced me not to do it.
Does anyone have a good source for bronze?
neither West or Boatfix carry male/male bronze nipples... everything else, yes...
The answer is no, but not for the reason that you think. While some wisecrack will try to tell me different, I will continue to state that there is no "official" agreement on the definition of "brass" or "bronze". I don't care what the wiki says or what you read in your science book. The two terms in a PRACTICAL sense are ambiguous. when I buy metals, the term "brass" is usually used as a CATEGORY of metals based on copper including both brasses AND bronzes and others. Many folks have gone looking for "bronze" nipples and such and only found one supplier. We have been through this before. So have I. Here is what I found.
You have to dig deeper. You need to find the more descriptive name of the alloy. In the last conversation of not wanting to put brass parts on a bronze thru hull I did some research and discovered that the alloy that was being sold as the "bronze" thru hull was exactly the same as what was being called "brass" in the nipples. It was a perfectly fine marine alloy.
So, my message is that unfortunately you won't be able to just use the terms brass, bronze, marine brass or even silicone bronze to know what you are buying and whether it is appropriate for the task. Your going to have to do some research, choose that right alloy and make sure everything is up to standards and compatible.
Also, the folks who were previously promoting the "one outfit" selling bronze fittings, turned out to be selling the same thing as everyone else. They were just calling it bronze.
I don't recall the alloy names right now, have it written down somewhere. Maybe someone else will chime in with the specifics. Somewhere here, we have a fellow who runs a foundry and is more than qualified to vet what I am trying to say and chime in with some even better advice than I am trying to convey.
I do pour brass in my backyard foundry, but I'm hardly an expert. Maybe my fellow foundry owner can give me some pointers!
bp
Bronze is a hybrid of aluminum and brass, and brass is...well, brass...you could use Stainless Steel.
Here's an article comparing brass and bronze in boatbuilding..
From a portion of this article: http://www.testrong.com/havenbuilders/bbsales.html
Brass vs. Bronze
I have found that many novice builders (and even some professionals) do not know the difference between brass and Bronze. Worse yet some of the larger retailers of marine supplies and a few of the smaller manufacturers are now praying in this fact. The are now selling "Bronze" fittings that are really made of brass and counting on the fact that most people don't know the difference. A few use a "Red Brass" that looks like Bronze but many are now even using a "Yellow Brass" which is a very low copper, high zinc alloy.
By definition Brass is an alloy of Copper and Zinc (and usually lead). Bronze is an alloy of Copper and Tin. This may not appear that important a difference but it really is.
First: Bronze is much stronger and more corrosion resistant than brass.
Second: Bronze is harder and more abrasion resistant than brass.
Third: As brass deteriorates is creates an oxide (a grey white powder - zinc oxide). Zinc oxide is acetic and will attack the lignum in wood. Once the lignum is gone the wood fiber is open to rot.
Are there any good sides to brass? Yes, but only for the manufacturer not the end user. Brass melts at a lower temperature and therefore used less enegry to melt. It machines and polishes much easier than Bronze and therefore the price to make a fitting from it is lower. Also, it goes away much more quickly and therefore the customer will have to purchase replacement parts much sooner. (It allows the manufacturer to have a built in supply of repeat customers.)
Without going into the minutia of all of the minor "ingredients" and variations, what has been my understanding is that "Brass" is copper alloyed with ZINC, and "bronze" is copper alloyed with "TIN".
To expand on what destin2 says, the Zinc in the brass is destroyed just like the "zinc" in the boat's zincs (which are not always pure zinc). So if you are "eating" zincs--the brass, will be "eaten" the same way and by the same processes--both electrolysis and corrosion. There is a good article on this at: http://www.copper.org/applications/rodbar/pdf/7013.pdf The addition of other alloys to "Brass" will help to decrease the dezincification of the metal. The line between brass and bronze is not as clear as one might think.
Might want to check your facts.
Easy . . . zinc in brass is going to be leached out by electrolysis. This will lead to the sinking of your boat.
Bronze doesn't do that 'cuz there's no zinc. And it's stronger, too.
KIDa, That pretty much says it all !!
When arsenic is added to Brass.....
Arsenic: Arsenic in amounts of 0.03-0.25% confer high resistance to 'dezincification', a specific form of corrosion.
You guys DO realize that most of those "bronze" thru hulls you are running around with have zinc in them don't you? It's all not quite as simple as you want to make it out.
bp
So many half-truths here. This is kind of technical, but I'll try for some easy reading here.
There's over 100 different alloys in the "brass / bronze" family of alloys and each has their place.
Brass typically has a higher content of zinc than bronze, which lowers cost cost of the part because zinc costs less than copper. Other ingredients depending on the alloy may be lead, tin, iron, nickel, aluminum, manganese, silicon, etc, in varying amounts.
For MARINE application, as mentioned already, bronze should be used. A big factor is a type of corrosion known as Dezincification. With this, alloy looses it's zinc content which will cause brittleness and failure. The key is avoiding this factor, which most retailers don't have a clue about it. Dezincification occurs in the brass family of alloys with a zinc content of above 15%. Brass that is yellow in color have upwards of 30% zinc content, whereas the red colored brasses have less (more red because of higher copper content) zinc, but still more than 15%. Some of the bronze alloys have less than 2%, however some such as manganese bronze has 22-28% zinc. Note that manganese broze is very popular in the propeller field. It's a cheap alloy, and machines very easily for machine shops, but IS suseptable to dezincification.
So how do you tell the difference in alloys...a trained eye can the color difference in brasses. Go with the darker colors, but if they're marked with "aluminum bronze" or " silicon bronze", you're in business...but you'll pay more. This is the problem in marine stores. They may loose customers if their silicon bronze is competing against another retailer selling brass because of a big price difference. This is where education comes in.
The cause of dezincification is from to much current, which can come simply from disimilar metals. Sometimes it's worsened when an anode is attached thinking it will solve the corrosion problem, but in reality, "more current is now inserted into the system, and the problem intensifies.
Did this help, or are you totally confused now?
