Bravo 1 Rolling Torque
blr
I am measuring the rolling torque of the U-Joint Pinion Gear Assembly on a Bravo 1.
When measuring rolling torque is the reading taken from a stationary position or is it taken once the shaft is turning in which case I would subtract the pre-load torque??
Thank you
The torque value is given in the Bravo stern drive service manual. It is preloaded before reassembling the pinion gear assembly into the upper housing. It's something like 6 in/lbs.
Please check the service manual listings under the sticky in the engine forum.
