Broken supply fitting on water holding tank
I worked on the boat this weekend and discovered there was no water supply when my water pump turned on. I found out the supply line fitting at the top of the holding tank was cracked. The fitting that comes out of the tank is now so small, I really don't have enough to attach to. What is the best way to reconnect the line to the tank? Thanks for any help.
