Broken VHF Antenna
tarbnelson
Ok, I did it. I forgot to lower my antenna when I docked my boat in the boat house. Can anyone give me my options? Can I splice the new antenna in to the line for the old one avoiding the work required to "snake" the line back to the radio.
Any specifics would be appreciated!
TN
If you don't care how it looks, you can wrap it with fiberglass tape and epoxy.
If you are careful you can attach a male PL259 connector to each end and then use a barrel connector. A reqular splice won't work too well because of SWR problems. Luck. Dale
Bite the bullet, eliminate the aggrevation and likely problems---just replace the entire antenna and be pleased that it will work well and reliably.
My thought exactly. There is shielding and continuity wrapping within the core of the antenna which will be compromised because of the break. Just replace it.
I like this solution because it also will ease future problems if you again forget to lower the antenna.
G
Thanks all. New antenna has been purchased. Recommendation for installation has been received from the guy who installed it the first time and confirmed by Cruisers, Inc help line.
Again thanks!
