Anyone with a Mariner/Voyager in the 28' range know what their AC's BTU is?
I am looking at a couple of units. Can't figure out how much BTU's I need.
Also, how is your Vberth's AC controlled? Is there a thermostat in there as well or do you just adjust the vent?
I assume the units sit under the dinette, where is the ducting run to get to the Vberth?
Here is a 16k unit I was looking at but I only have 30 amps to work with and it draws (soft start) 12-14 amps. The 12k unit draws 10-12 amps but I don't know if 12k is enough for a non insulated boat.
I am on the great lakes.
