Buff-Magic clogs up the pad?
davida
I am using Buff-Magic on a Harbor Freight buffer with great results on #1 speed. The only thing I am experiencing is that the 3M white wool pad loads up with B-M and gets very sticky and blackish and won't take the B-M off of a new area as well. Because it is so sticky (like heavy grease) spurring doesn't work either.
Is this normal or am I using too much B-M or doing something else wrong?
Thanks, DavidA
I think you are using too much.
My pad loads up but not that quickly.
You might want to try a different style pad, the white wool pads are for heavy compounding, try a polishing pad I think #3 (yellow).
Blackish? Buff-Magic doesn't tend to burn, so I wonder if you're picking up dirt and/or hitting metal fittings. Cleanliness of the pads and surface makes BIG difference.
(and I agree - too much material is also a likely issue)
I think you are right, it gets blackish when I go over the SS rub rail with black plastic insert.
If you want to polish your metal with BM, do it last after you do the gelcote. The pad will turn black like SLW says.
BM works great on stainless, glass, plastics....
I have read a lot of good things about buff magic. Could it be used to clear up a clear plastic windshield that has got light scratches because of bad cleaning practices.
Any one tried this.
It seems so effective, I wonder if anyone has used it to whiten teeteh? ;)
Any one tried this.
I've used it on plexi and lexan on it does remove scratches.
Give it a try, I don't think you can lose either way with it.
