Buff Majic is pretty impressive
VTBoater
After reading all about buff majic here on boatered, I decided to buy some from boatfix and give it a shot. I am very pleased with the results I'm getting. Kind of a slow process as the boat did not get waxed last year, so there was slight oxidation. After two different speeds of working it in, the hull has a nice shine.
Thanks to all the good advice here on boatered, despite my previous reluctance to reanchor, I plan on coninuing support to this website. There is a lot of good info to be had here.
James
I was not so pleased with my results last year using Buff Magic. Maybe user error, but did not live up to the praise I've ready. Changing to a different product this year.
On the other hand, I really like Yacht Bright Serious Shine and Serious Marine Cleaner.
VTBoater, glad to hear it worked out well for you. This is my second year using the BM & PP on my Regal 322. I was very happy the way it came out last year. This year I was amazed at how easily it cleaned up prior to doing the BM & PP. It came out even better this year. The green stripe came out amazingly clear, like a mirror. It now shines like a brand new boat...I've been getting a lot of compliments on it.
b_arrington, I'm betting user error. My friend was getting not-so-good results on his Rinker until I showed him how I did mine. You can't use too little of the stuff...a little goes such a long way. The right polisher speed and good pads are also important.
Big thumbs up for Yacht Brite products from me.
Be sure to follow up with Pro Polish
I tried alot of stuff from WM imc;;uding 3M with no result till I tried BM this weekend I actually got a shine on my 22 year old hull
I used Buff Magic last year. When the shrink wrap came off this year it still looked great. It will definately be easier to clean this year than last. Great product and I will follow it with Pro polish again. I purchased both here at Boat-fix anf saved about $14 vs. puchasing at my marina even with the shipping. I received may product only two days after ordering.
I used BM & PP for the first time last year on my 1986 Silverton. It had been buffed when I bought it but it still never really looked clean and waxed. After using the BM/PP it actually shined. This year the spring application went on even easier than last year so I was happy with it. Now if I could just find something to remove those darn black streaks after the rain!
I have tried it all. I even did the stuff that goes on like a top coat. This year I went back to the old days and did my Sea Ray 34' from top to bottom with Carnauba wax.
I'm getting a load of complements on the finish and its as hard as nails.
I'm very happy with it.
I put it on with a Bosch DA (or Random orbit) sander with a sponge attachment at slow speed. This rubs the wax in nice and slow with even pressure, and keeps it thin at the same time.
After it is dry, I hand wipe if off with a nice big towel like it was my last step.
Then I polish the surface with a 10" finishing pad on a angle buffer at a fast pace letting the entire pad contact the surface, NOT the edge like you see auto body guys doing it. I let the buffer float over the surface with just about no pressure and it shines like a mirror.
No swirl marks ever. The second coat if you do one is really nice. I can do the whole side of a 34' boat in about 20 minutes using this method.
Buff magic then 3 to 4 coats of Rejex. No wax especially with diesels. Diesel wipes right off and no discoloration.
I h ave to try Rejex next year as I'm not real happy with Pro Polish. Still love Buff Magic though.
I googled Rejex a while back and saw only stuff for cars. Is that what you use?
Mike,
I got my Rejex at Lasihley's
I've been there and done that.
I've moved away from Buff magic, I prefer to use a diminish abrasive and all foam pads.
I feel a 3M white foam cuts better with less swirl marking when using diminishing abrasives. I use Presta Super Cut Compound, followed by Meguiar's Premium Marine Sealant.
Works on dark and light hulls.
JC
Try finding Presta Super Cut in you local ship store? Buff Magic is pretty much everywhere.
