Buffer?
I Know there was a thread in the past about which buffer to buy. I would like to order ASAP but want to make the right choice. Please advise, Thanks.
I have heard really good things about the Makita 9227c, and I'm planning on buying one this spring. It is NOT a random orbital buffer/polisher, so you have to be cautious when using it. You can find it online for less than $200.
lets say money is no object whats the best and start there. I may have to settle for less then the best but if you had your pick what would it be?
Timeout the Makita is the one I was looking at but I heard somewhere that there is a model that is a heavy duty variable speed and can be switch to do orbital as well. I'm not sure what brand may have been Porter cable.
Then the Makita. But I get just as good results with my $49 Harbor Freight buffer that I have been using for 5 years.
Look at the Hitachi SP18VA as well only for one reason. It is lighter than many of them, especially the Milwaukee. Introduced to me by a fiberglass professional repairer, he has used one exclusively for 10 years. Last season we brought back 2 very faded 1996 dark blue hulls to what looked like the factory finish, believe it or not.
We used a 3M superbuff pad, 3M HD rubbing compound, then Awlgrip polish, then 2 coats of Collinite Paste wax. Absolutely unbeliveable and it lasted all season. End of season, I washed it and rewaxed. A lot prettier and cheaper than applying Awlgrip.
We did 2 dark blue hulls and one cream hull with the HItachi that was not even breathing hard.
By the way this is all done around 1000-2000 RPM's, and really worked into the surface till each step shines, not a quick job! But gratifying.
But being cheap, I would try the harbor freight for $50 (what the hell) as long as the weight was not more than 7 lbs.
I post a couple of photos, but have no idea how.
I used elcheapo variable speed Wen or sears brands for years without problems. All plastic so the pros don’t like them but that makes them light weight which is a benefit for overhead work. IMO price doesn’t matter much because they are all hard to kill.
sorry I not much of a procrastinator I ordered Makita 9227c with kit for $179 I know a few people with it and they all seem happy. I like to buy something once and be done with it then move on I tried going the cheaper route several times with not such good luck. But I do thank you for the input.
In my case I had ten or more years of heavy fiberglass oxidation that had to be cut through on a 36 ft trawler. You cannot do that with that type of polisher you describe. We needed to swing a 7" wheel cutting with HD rubbing compound. I do wish they were lighter though, which is why the Milwaukee is not the ideal tool for boats. Well built of course, but tough on the arms.
By the way, that brings up a point that we learned form another old boat polisher. DO not extend your arms. Lock them is and keep them close to your body. Any machine will be heavy on the arms doing vertical boat hulls. Enjoy!
I bought a hi-speed buffer from Harbor Freight. We have a local store. It has adjustable speed and only cost 25 bucks. Dont skimp on the pads though, they are what do the work and cost as much as the buffer. lol 3 yrs later and it still works great. Downside is its heavier than the expensive buffers.
You made a good choice, it is a good machine.
Just think about it, all this discussion not one of the choices could have been an American Made product.
(Maybe you could hire a Chinese, Mexican, Ecudorian, Brazilian, or Guatamalian to do the actual work with some foreign made wax products. (Or, an out of work financial worker).
Maybe you could qualify for a bailout and apply for stimulus funds and then hire a foreign worker!
Makita 9227C is the best available with no consideration of cost.
Buy a 3m SUPERBUFF 7" PAD. It is wool, heavy duty, two sided. It is washable. Use it for rubbing, polishing and wax buffing. You only need one pad, this is it. You may need to go to an autobody supply shop to find it.
You also must have what is called a rake. Some guys use a screwdriver, but it is too sharp. It is used to clean the pad every few minutes. It is essentially a group of dull star shaped steel on a roller type arrangement. Costs about 10 bucks again at the autobody store. The pad can be 30-50 bucks buts will last years. It is self supporting, you will need nothing additional, no foam pads, no cloth, nothing except the proper liquids! 3M Superbuff. At least the wheel is made in the US!
Some additional info. The pad is also sold to fit a 1/4 drill. This is not the one you will need. You need the one that will fit the buffer arbor and depending on what ships with your Makita, may need and adapter, mine did.
Go to Jamestwon distributors for a complete description.
3M-05705 Superbuff Polishing Pad are double sided, soft edge polishing pads that are designed for use with a polisher and a glaze. Made of extremely fine wool-acrylic blend fibers, these pads produce a high gloss on paint and gelcoat surfaces. Superbuff pads are double sided with a built in support system that eliminates the need for back up pads. Use the 3M-05710 Superbuff Adapter to fit pads on any standard 5/8 shaft slow speed polisher.
http://www.jamestowndistributors.co...2683&familyName=3M+Double+Sided+Polishing+Pad
This is not as hard as it all seems. You need 3 things, the pad, the arbor and the rake tool. Happy buffing!
I agree with Bruce.
Unless your a pro with big arms, I've never seen the point in paying top dollar for one of the heavy weights when you're just going to use a buffer once or twice a year.
If you only need to shiny up a shiny boat you don't need anything, just a bunch of clean towels and some good wax. The elcheapo buffer may help for this work, but subjective. But, If you need to shine up a faded boat, that is another story which would be the only reason I would go to the bigger machines. But, they are much more powerful and do the job much faster, with a lot less arm tire than you would think if you hold it properly.
To each his own in his own way in his own time with his own boat which is the enjoyment. So, if you want to polish it with a artists brush, a mink coat, a buffer or old underwear, just have fun.
You got a good deal on the Makita and it is a great unit. I bought one myself. Never can go wrong with a Makita.
For years I would borrow a friends heavy duty single speed off brand buffer and yes it worked OK but it still took me 2 full days to do a descent job on a 33' boat. In all fairness it was a bit faded and had three colors to the hull each color had to be done one at a time front to back then clean the wheel then repeat with next color for cleaner, then wax. Now I bought a 44' boat however it's all white I'm hoping it will be easier to wax it is not faded or it wasn't when I put it away. I just want to do it right but do it quickly. Time spent waxing could be time spent earning money, unfortunately it won't offset paying someone else to do it and even if it did I do a better job. At least I try harder.
