Hi Bill - I have a '97 4085 and have been very pleased, overall, with the boat. I have the diesel version so I can't comment on the gas performance, however, your friend should get a good idea of performance during the sea trial.
There is a design issue with the boat that your friend should be aware of and check out during the sea trial. Specifically, the boat was designed to maximize interior space and the trade off for the large aft berth is a cramped engine space with a lot of weight stuffed into the stern of the boat.
From a performance standpoint, especially with full fuel tanks, the aft weight causes the boat to want to ride bow high which restricts forward visability. I dealt with this by increasing the size of the trim tabs and using them virtually all the time. This may be less of an issue with lighter gas engines and your friend can make that determination. Also, have your friend check the access to the outboard side of the engines as this is a problem with the diesels. Again, this may be less of a problem with smaller gas engines.
Remember, this boat was designed and built by the Bayliner Motoryacht Division and I've found the mechanicals, wiring and quaility of components to be of good quality. The interior fit and finish is OK but not great.
Good Luck to you friend,
Tom
