Cabin Window latches
clearseasII
On my 2003 sea ray sedan bridge,the cabin windows ,are the push out,pull in type with 2 handle latches on each. The problem i'm having is that one latch on each window.where the latch is screwed into the metal frame has come loose.i've tried tightening but they keep comming loose.short of replacing the entire window frame,i have no idea what to do
i wonder if the screws are stripped? do they actually tighten, then back out...try locktite.
no,screws are'nt stripped. they actually pulled right out. when i apply pressure on the latch,the hinge base/bracket pulls up
