Cabinet door supports....
rommer
Our head's medicine cabinet door is about 3 feet wide and 12 inches high with a mirror and is fairly hefty. To open it you have to swing it up towards the ceiling.
Sometimes it will slip out of your hand and slap down pretty hard. I'd like to install a pair of gas struts to slow the door down on closing but I can't seem to find any instructions on how to layout and calculate what size I would need to purchase.
Any pointers?
There are a couple of ways to mount. with only 12 inches, I would mount one end about 3" from the hinge of the 'frame' side and the otherside on the 'door' side. Use the 'L' bracket mount(on the door side) that will offset the anchor point 'inward' so it will have a positive force trying to keep the 'door' closed. The strut will be about 9" closed and 12" extended.
There are 3 main measurements for gas springs, overall length, stroke length and weigh class.
Be careful not to get too heavy a gas spring. If you do the hinges will take a beating.
Boatfix can order these Attwood springs, they had the best price, I just changed 5 of them on my boat. Pricey but they are stainless and should last what's left of my lifetime.
http://www.attwoodmarine.com/produc...Spring&headername=Gas+Springs+and+Accessories
Jonathan
