I took the props off today and soaked them in Muriatic Acid and it occured to me that as long as I had them off and was cleaning them anyways.....It probably wouldn't hurt to look and see exactly what size they were. This Boat came from Florida about 5 years ago and the previous owner had painted them (or something) and that along with the Salt Water turned them rather ugly. I got some Sand-Paper and after soaking them for a while started sanding and I must admit they do look ALOT better. Now you can actually tell that they're Stainless Props and not just really cruddy looking Aluminums. Anyways......
On the Hub there's a set of numbers
48-79794-17
On the same surface of the hub but 180 degrees to the other side of the face....
6473
On the outside of the prop there are two sets of four digit numbers stamped into it between the blades.
0181
and
6761
I have not a clue what size prop this is. Anybody got any ideas?
48-79794-17
6473
0181
and
6761
