Can I do this, will all work?
Moderator
I bought this zinc plate a few years back from boatfix, it was the wrong plate, the one I need is a DD-612 (DP1)now called a DP-612 (DP1), which I can't find on boat fix.
Anyway,
The plate does not fit over the studs that come out from the back of the boat. I was thinking I could just enlarge the hole (just a little bit would make it fit)and then bolt it on.
This plate is all zinc; the one I should use has a metal insert in the slots that bolts to the boat. See picture B. The zinc I have is in picture A. Will I get the same conductivity using th zinc in picture A, in other words, will I have the same protection?
Picture A, What I have
Picture B, what I should use (came with the boat)
They are both the same physical size and thickness.
In a word: YES. Exposed area is all that matters.
Drilling it could cause it to corrode faster in the area drilled though.
Not sure if they coat these with something after molded.
I notice that most zincs do fall off due to corrosion near the fastner.
Using oversized washers to hold it in place may help.
I would assume as long as there is good contact between the studs and the zinc plate....it will be OK.
I've been doin' it for 20 years. No, there is no coating on the zinc. Use washers under the nuts that hold it on. That which is important is the total mass of zinc electrically connected to the metal parts of the boats that you want to protect.
If there was a coating on the zinc, it wouldn't work.
its surface area of the zink not total mass.
