Can someone repost please
  • Thread starter Thread starter blouderback
  • Start date Start date
B
blouderback
Guest
I guess my other post about reading charts got too hot to keep around. However, there was some good info on it that I didn't get a chance to copy.
1. What was to link to that Chart 1 thing?
2. What was the link to the Power Squadron (or was it CG Auxilary) site that had free classes?
Thanks in advance, and thanks to all of you who posted on the other thread. I truly did learn some things from some of you - Flutterby, Les, Agent 86, and especially Hyperfishing who was familar with that area in particular and told me about the "shoal". Sorry if I forgot to thank anyone personally, but I can't remember exactly all those posters that actually contributed good info.
Just wondering, do you have a fishfinder and chartplotter? GPS, anything like that?[:-eyebrows]
Bob, BoaterEd sells a very good book if you want to read up on Navigation. I have it and bought it when I took their into online self taught nav class. I don't think they do it anymore (I could be wrong), but the book was great. I still have it and refer to it at times. If you like technical stuff about boating, you'll find it interesting, even if you don't use half of it.
Here's the link. Les, is this still valid?
http://www.boatered.com/course/navcourse.htm
I have a handheld GPS, and a digital depth sounder (just gives me depth, no bottom picture or fish) that's it. Like I said before, I'm not looking at doing any major navigation, I just want to know how to recognize shoals, no wake zones, no anchor zones, and stuff like that. I'll always be within swimming distance of land with this boat. Maybe someday when I get a little more adventurous, and I've upgraded to a nice 25'+ closed bow boat with dual engines, then I might try the open waters a little bit.
rule nr 1 ... keep it between the markers, dont' take any shortcuts.
rule nr 2 ... in doubt, take it slow. if you don' know where you are, you are better stopping instead of getting stopped by a shoal or rock. either way, the boat will stop !
get chapmans... it's the bible of boating, use it to look up any question first, before asking here since it seems simple questions are increasingly frowned upon by teh resident gang of self appointed experts.
charts are easy to read, look up the symbols in chapmans... it's not rocket science, you can do it on your own with the book.
It's close to land that you have to worry about hit it, off shore theres not to much to hit but other boats. I think the CG basic boating corse would be a good place to start. With your sounder and a chart and compass you can learn dead reconing enought to get by with the best. My biggest troubles I have, been the fog, I allways 2nd guess my self, radar, 2 gps chartploters,and still been in places where i was 100% sure, I was where I want to be , but off enought to make me wonder. Experience and knowing your area is what makes a old salts. But as I think back I've had little boats, gone 50 miles or so. told the wife "remimber that sailboat thats were we have to turn" well when we came back there was no sailboat. My wife still reminds me of that day. I wouldn't every let that happen again. that little boat had a 12" draft and my boat now only have a 26" draft can go just about anywhere still.[:-bigeyes]
freedy, you are correct. I hadn't thought of it that way, but I guess it's much easier to run aground or hit a rock where I'm trying to boat than out in the ocean. Just a heck of a lot easier to get lost in that big ocean thingy, and if something breaks, a lot harder to get back.
Shoaling is marked on charts, it merely means look out for moving sandbars and buoys may not be correct. Of course, shoaling can happen in areas of the chart not marked shoaling also.
This boating site is excellent for detailed knowledge of experienced boaters in whatever area you plan to boat. As in "watch out for minimum depths and incorrect buoys at ....
Two fish finders/depth gauges, two separate chart books, a handheld battery powered GPS and a separate GPS chart plotter are minimums for extensive cruising, plus two radios and all required safety gear of course. Why two of the chart books and electronic thing-a-ma-jigs? Because one usually fails when you need it most.
Thanks Chris. If I took all that equipment on my boat, I'd be over my max weight limit! :)
Well, without all the stuff I listed, my wife and I would likely have been part of the Coast Guard's "watch for floating body" broadcasts.
As seen on the boat accident threads, boating all too often equals fun turned deadly. I wear a nasty scar on my face and many other scars from boating accidents that eventually added up to knowledge.
I hope the BoaterEd information will help you avoid a few scars or worse.
Bob, I've been on vacation and I suspect you have received a -variety- of responses while I was out...
Every boater ( and prospective boater ) should have a copy of Chapman's. It is a good quick reference, and covers most simple situations. Every task in life has it's learning curve, and a certain amount is necessary to get off of the ground. Chapman's represents what most people think is the minimum required to be minimally safe enough to enjoy boating. And while I personally study this kind of stuff to death, I recognize that my level of study is not for everyone.
The "horse's mouth" of charts ( in the USA ) is "Chart # 1". It is the complete legend to all US charts. If you see a symbol or mark on a chart, the text description will be found in Chart # 1.
What Chart 1 ( and Chapman's ) do not explain throughly is that though charts are accurate representations of the water surveyed, they were only accurate -on the day that they surveyed that spot- !!! This means that not all data on a single chart is "current". Data for marked channels. esp those with heavy commercial traffic, should be the most accurate data. Other areas will have data that is less recent. I know of one chart for my area that has vast sections where depths were taken by lead line, just post Civil War ( 1865 to 1899 ). So be careful, pay attention to "what the water looks like" and avoid areas that "look funky" even though the chart says you have enough water.
The courses mentioned previously often contain this kind of info, and are quite useful, even to those with considerable experience. And while I would like to see all new boaters take a good course, it is not ( usually ) required. But you do need some basics, and the best "first timer" reference is Chapman's.
Good luck. Be safe.
Available used, quite often, at various amazon type sites.
Definitly good advice. And remember that the channel markers may not be in direct line of sight. Can't just fix a straight line from one red nun to the next.
With that in mind, I'd really invest in a good set of paper charts for your area - a handheld GPS is great for telling you where you are in relation to a small area but is difficult to plot further out. We have the ADC chart book and it's super easy plus you get chart #1 :D
one other thing, check out the notice to mariners (avail on the USCG site) for shoaling, missing markers, etc...
dont' overly rely on a sounder... it tells you what's under and behind, not ahead. yes it's a tool but nothing more.
Chart 1 is free on line, you don't need to buy it - but you do need to use it. Coastal Navigation is required knowledge for any boater on "big" water. There are lots of good books on the subject and, as mentioned, we offer a course here. Frankly, I can't imagine any boater heading offshore without the ability to navigate by chart and compass. Even the use of a GPS requires an understanding of set and drift, latitude and longitude, SOG and STW, and other fundimental factors. The nav aids system can get confusing, especially with primary and secondary channel markers and the unique aids on the ICW.
YIKES! Went to download Chart 1, and it's 84MB! That's gonna take a long time on my 9600 baud modem.
