Canvas or Partial Shrink Wrap?
capt2stu
I am trying to decide whether to buy canvas for my 1993 Carver 330 Mariner to use during the winter, which should last a few years, or have her shrink wrapped.
This is my second season with this boat, last year we had her hauled and the whole boat shrink wrapped. This year we are going to leave her in the slip with several other boats, and use ice eaters (the marina has workers year round checking the piers every day). Because it only has a catwalk on one side, they said could only shrink the bridge and cockpit, which he felt was fine.
I am also looking into a canvas cover for the bridge with cutouts that I could also use during the boating season with the bimini up to use at times without the full canvas up. I have been told not to worry about the cockpit, just check the drains once in a while as that would be the main problem if they got clogged. Another person told me they wouldn't worry about that as it is the same in the summer in draining from rain, but would worry about the weight if there was a lot of snow sitting there.
I am leaning towards getting the canvas for the bridge without the cutouts, could always add the cutouts in the spring if I wanted to use the canvas year round, and using some kind of tarp to cover the cockpit.
Any thoughts? We are in Maryland.
Stu
I don't use shrinkwrap and purchased a winter canvas enclosure for my flybridge last year. So long as you keep leaves off the cockpit drains, you should be fine. Last year was my first time not using shrinkwrap and all was okay. I'm in NJ.
Good luck,
Stu,
We have been keeping boats in the water all year in Annapolis for the past 15 years. The biggest problems we've run into is getting on and off the boat when its covered with snow and ice and adjusting/checking the dock lines (we can get some pretty good wind during the winter). I cover the entire boat with gray tarps as close to the water line as possible using lots of gallon jugs to keep the tarps down. If your engines are under the cockpit I would sugget covering it to keep them dry, plus snow doesn't drain well. If we have a big one, I'll bet those dock guys are at home and the power is out at your slip (i.e. the bubbler is not running). Of course we could have another mild winter with no snow...... Tim
Appreciate the replies.
Tim, my engines are under the cockpit, so I decided I will buy a tarp to cover it.
I just talked to the person who will make the canvas for the bridge (who is also a member of my power squadron), and we decided that he will make the cover for the winter, and then if I decide to use it for the boating season, he can add the cutouts later.
Stu
