Canvas repair question
regulator
From the looks of it, someone had a little too much 4th of July fun. I went out to the boat yesterday to find a 3 small burn holes in the aft section of my camper top. They are closely spaced together (about an inch wide) and are about 1/4 the size of a cigarette burn each.
What is the best way to repair this? Can I simply cut a small piece of sunbrella and glue it to the outside? If so, what glue would I use?
Since these are so small and so close together, the color match shouldn't be a problem.
Thanks!
The sunbrella site lists a couple dozen compatible adhesives.
Boy, I would be soooo p!$$ed off! Too bad you can't find out who did that. One more reason to not smoke!
I have seen that type of probelm from fireworks--and that is why they should not be allowed in marinas or crowded anchorages. I noticed a piece in the local paper where a couple was arriving home from the 4th of July fireworks and watched a flare slowly arc into their boat (the article didn't note if the boat was in the water or yard, but the area has many waterfront homes)--the flare was still burning and started a fire on their boat.. Lots of damage.
I would be sure that the edges of the hole are sealed. Since they were done with heat, that is probably OK. I would use Dap 121 or 3M high strength adhesive 90, plus sew the edges of the patch on the underside of the camper top.(patch 1/2 beyond the edge of the burns, and heat seal the edges of the small patch. For this I wouldn't roll the edge over) You can either hand sew or have a professional shop do this. If you use a monfiliment thread (harder to use) the patch will be virtually invisiable. Sure makes you wonder about some folks! Good luck on the repair!
If you want a simpler repair, we have had good experience just painting a little nail polish around the hole. Then get the iron on patches for repairing blue jeans at walmart. They come in a large variety of colors. Iron a small patch on both sides. It will hold forever. If ou can get a good color match and cut the patch into a small circle, it looks pretty good.
Charlie,
I like that idea! Black should be pretty easy to match.
Is it waterproof if I spray it with some 303 fabric protectant?
Actually KnottyBouys, do you have the link for the compatible adhesives? I found some spare original canvas that I can use for the repair.
I looked everywhere on the sunbrella site and cannot find them.
Careful! The Sunbrella website to never use heat on their fabrics, especially irons!
C'mon Liz, if do it yourselfers paid attention to warnings, nothing would ever get done. Seriously, that type of patch lasted 5 years until we sold our last boat.It was water proof with no help.
Regulater, I recently used "Duro" spray contact from walmart to bond the foam pads together on my beds. It says that it's compatable with fabrics but I have no idea how it would deal with rain. The iron on patches wore well because they are designed for continuous washing. I think it helped to patch both sides. We've sewed canvas and sunbrella by hand and on our little Singer.It aint fun without a heavy duty machine.
Correct on useof irons, but hot cutters are very commonly used in fabrication. I suspect that a match which would stay the same in time from Wal mart is unlikely, you will not find Sunbrella at Walmart. A quality repair will help preserve the value of your boat--not so sure of an ironed on patch.
