I think most intake manifolds are dual pattern these days, in that they accept both square bore and spread bore. Square bore has all 4 barrels the same size and spread bore have like 1" primary bore and 2" secondary bore.
Personally, I love the spread bore. The small primary bores run very efficiently and are stingy on gas if set up right. I got the Holley 4175 Q-jet replacement. It's Holleys version of the spread bore. It can be set up so the vacuum secondaries won't open until that last 1/4" at full throttle, when you need it. Otherwise you run on those tiny 1" primary bores. So you understand why the small primaries work so much better, it's a matter of the speed of the air trying to rush thru the small bores which creates low pressure. The faster the air flow, the better the fuel is sucked from the float bowl. The faster air flow also atomizes the fuel better. I found my 4175 on sale at a marine warehouse for $275. Turned out to be used but in completely new condition.
Virtually all newer manufactured carbs can be considered 'marine' carbs, mainly because the EPA regulations required carbs that would leak fuel to the air. This mainly meant preventing leakage at the throttle shaft, which is a marine carb. Of course, the EPA are a bunch of liberals that have no idea how things work, they just make rules thinking that would fix everything. Fact is, carbs HAVE to vent the float bowl to air to keep the air pressure equalized. If the float bowl were sealed, fuel being pulled into the carb would create a vacuum in the float bowl so fuel wouldn't draw into the carb at an even rate.
