I am very mechanically inclined. I used to restore 1950's cars. There are a couple of things I've always had done professionally at a shop that specializes, has the tools and equipment, to make sure it can be rebuilt, to both rebuild it, and to test the rebuild after finishing, I've tried to do myself and never have had any luck.
Blocks - Testing for cracks, boring cylinders, planing head mating surface
Carburetors - Replacing butterfly valve shaft bushings, testing float position, testing flow.
Crankshafts - Self explanitory
Distributors - Testing vacuum and manual advance
Differentials - Never could figure out gear "backlash"
Heads -planing surface flat, having the tool to grind valves at exact right angle.
Notice not manual transmissions....which should give you an idea of my skill level.
