Carbon Monoxide Detector, sensitivity?
Cocktail Time
Hey all, I have a Xintex CO detector installed that seems to be super sensitive. I have brought in a 115v digital unit that reads out well under any danger zones. Is it possible for a unit to need calibration or to become more sensitive? Is it a 98' model...
Thanks, Dan
I'm no expert at this, but CO detectors go off when your battery charge is low as well. Have you checked that?
I read in Powerboat Reports that you can send in your monitor to Xintex to check/recalibrate the sensor for $25. PR said that this should be done every year, because the sensors are damaged by many of the chemicals used on and around boats.
how old is it ? after a few years they usually need to be replaced.. or so they say :-) although i think it's beause they loose sensitivity.
and i believe that marine / non marine detectors compute levels differntly...
CO detectors are good for 2 to 3 years. Toss the old one. They are a chemical/electrical sensor element and disposiable. The most sensative unit which is practical is the AeroMedix CO moniter. The company has been in termoil since an ice storm damaged their facility last year. The Kiddie Night hawk is the next best item for a boat--the one with the digital read out.
You are looking a your life when relying on a CO moniter. You can buy a test kit--I am not sure about calibration, but I doubt it. --I suspect that if someone is "calibrating" them, they are just replacing the sensor.
they dont like having furniture polish or air stuff sprayed on them
