Carvervirgin, That is exactly what happened to mine. I knew there was going to be some defrost water and I laid a towel down before I left the boat, but there was so much more water than I expected, so the wet towel laid there for about two days and caused the floor to buckle. If I can get the buckled piece up, I will probably do as you suggested and go right over the existing wood with a vinyl maple plank (Allure from HD has been suggested). The only transition area is a threshhold between the forward cabin and the galley, everything else buts into a wall or step.
