Once warmed up my port 1986 Crusader model 350 / 454ci develops a miss. It shows on the engine sync gauge as a rapid deflection towards the strong engine. In the video below it is pretty bad. It starts as a sporadic, random miss. Then progresses to a more persistent miss. Increasing RPM makes it worse (video was shot after running at 3k rpm for about 30 seconds). If continued operation, engine dies.
When this first happened late in the summer of 2012 we changed the spark plugs and it ran great for another 10 hours or so. Just changed the plugs before taking a 20 minute ride at idle from my dock to the pump-out station dock. I let it idle around 800 rpm for 10 minutes before leaving the dock and all looked great. Idled away from the dock for about 5 minutes, then increased to 2k, 2.5k, and 3k rpm for about 2 minutes each. After about 1.5 min at 3k rpm the engine sync started showing some misses on the port engine. So, throttled back to about 1k and stayed at or below 1k back to the pump out station, then back to our slip.
The engine never died or felt like it was losing power. At the dock I idled it for several minutes and the port engine was missing every 10 seconds or so. Ran it up to 3k rpm for 5 seconds, then back to idle and took the video below.
Not sure where to start to sort this out.
Ideas?
https://plus.google.com/107462996218604913823/posts/VmsHR9MYdtS
Ideas?
