Why do boat builders build that kind of crap?
I had this conversation with my grandson a couple days ago. He is working for a boat/yacht repair company right now and has been dealing with these tight fitting places almost daily. I just laugh since I do all my own work on our boats.Why do boat builders build that kind of crap?
Thank you for adviseYou may need to remove the pump altogether. It s easier to replace impellers on the bench especially with limited access.
To the original question. I have similar problem on my Luhrs and since I can no longer squeeze to the outboard side of one engine I use the opening they placed between the cabin and the engine space. It makes for easy access to the front of the port engine. Do you possibly have such an access port?
One gentleman advised to remove the pumpI had this conversation with my grandson a couple days ago. He is working for a boat/yacht repair company right now and has been dealing with these tight fitting places almost daily. I just laugh since I do all my own work on our boats.
You can do it. I had to remove a pump on an old Chris Craft with the engine tight up to the bulkhead. In 100 degree heat and humidity. It was a 6 knuckle job and about 1500 F bombs. Took a week to recover.One gentleman advised to remove the pump
It’s easy on port engine
Starboard is different story
I will investigate that
Thank you all
That might be costly, depending on where the boat is located. But I'm sure he would be willing to travel.Call Bob's grandson....
