- Jan 20, 2002
- 7269
- 802
For those of you who might recall, I have had an ongoing problem with fuel getting to my port engine. I had replaced the fuel pump, fuel lines and both fuel filters to that engine and it seemed to work fine for a short while. However, yesterday I took her out to the local island and upon trying to start, the port engine ran for maybe 30 seconds and died. After several crankings, I switched to the other tank and she started. Switched it back to the original tank, and she ran fine the rest of the day. Today, I removed the fuel line from the tank, and anti-syphon valve. Found some gummy residue, valve seems to be working fine. I tried to remove the pick up from the tank. There is a welded threadlet with what appears to be a SS fitting screwed into it. I was unable to budge this fitting even after soaking for an hr with PB blaster. I can see no threads on the fitting and wondering if it is even removable. Can anyone shed some light on how this fitting is installed in the tank?
