The boss wants a dinghy, center console, and I need a bimini top. Then I will probably need Isenglas around it, so I can run my HEPA air cleaner and even the concentrator while out.
Hard bottom....jet type are good because you don't have a prop to ding up in the Delta, but they get poor milage.
We want a trailer so we can pull it out in the winter. But if we get a little smaller dinghy, we can leave it in front of our boat in the same slip. At least WB used to allow that.
The Boston Whaler is great for the Delta, but I was told it will beat you up in the Bay.
So which dinghy has a semi-displacement hull?
And what size dinghy do you need to be comfortable in the Bay?
Engine size? Is HP needed computed on the dinghy's length or weight? Of course you need to know what the manufacturer says is the max engine size to put on it.
This handicapped stuff is getting complicated. We would LOVE to find a used golf cart that would fit in the cockpit. Use the Davit to lift it in and out.
We found 3 or 4 that look like they might fit our needs. Am I forgetting anything?
This center console would be too heavy to carry up top, so we either tow it, or set the boat up to carry it on the swim platform area.
