I have never used cetol before, but my new (to me) boat has some teak that is finshed in orginal Cetol (not the clear version)
Anyway, I have both fore and aft flag staffs here at my home and wanted to re-coat them today. I hit them with 220 grit sandpaper and it ate right through the finish, which was not all that bad to begin with. It had a little depth.
Once I was through the finish in areas, I knew I had to keep going, so I stripped them both to bare teak. I will probably just varnish them as i dont have any Cetol on hand and they are just flag staffs.
My question is this, I have teak covering boards that have been Cetoled. Would it be more correct for me to just re-coat without sanding? Are you not supposed to at least scuff the surface when re-coating. I am concerned that i will wear through on those and I really dont want to have to strip them as they look pretty good as they are.
Dan
Dan
