I would prefer doing both if I were in the northern climes. After changing oil and filter in the Fall, run the engine well to circulate the fresh oil throughout the parts, and then call it a season.
In the Spring, I would run the engine well for the first outing, and then change it--though probably not the filter--unless really motivated; as we often get in the Spring!
It's cheap! Why not do both? It makes you feel good!
Paul
