changing leaking group 29 batt
booboo
I found my port engine battery was not holding charge. Found liquid in battery tray and crystallized dried stuff in bilge under batt. It is in a tight spot and heavy. Should I sprinkle baking soda on batt before attempting to.remove it. What do others suggest?
Can you lift battery out with battery box? This is why I switched to AC Delco Voyagers which are sealed & maintenance free.
sprinkling baking soda on top isnt' going to accomplish anything although you will want to clean the cable terminals and neutralize any acid that may have spilled outside the tray.
did you check the water level? are you sure the battery is leaking and the water isn't coming in the tray from a leak somewhere? seems unlikly but it can happen.
if the screws holding the tray are on the outside and you can get them off, take the tray out at the same time, use rags aroudn to make sure acid doens't drip elsewhere.
Have a helper nearby with several supermarket plastic bags held open and lower it into one, then lower all that into another. Better, lay some paper towels in the bottom of the bags first since they sometimes have small holes or tears along the seams.
I'd want to get it out of there and determine if it is leaking while it is far from the boat.
