Changing Raccor Filters
Northern Ivy
Good day; I want to swap out the my raccor filter as I have been seeing some black sludge in the glass bowls. I think that the batch of diesel that the boat had on board when we bought it was bad (as we had drained a lot of water until most of the fuel was burned).
Could someone confirm that this is the process for changing the filter.
1. Close fuel supply and return valve to raccor/rank.
2. Close crossover valve.
3. Remove "T" handle
4. Remove and replace filter
5. Replace "T"handle
6. Open fuel lines
7. Start engines
The second question that I have is this; is it recommended that you drain some fuel out of the bottom of the raccor one the fuel line is open again to purge the air from the filter? Or since you close the fuel line before you break the seal on the "T" handle will diesel flow on its own once the valve is open?
Thanks in advance; I assumed that if the engine would idle for 30 mins after the filter swap that all is fine?
4.5 fill filter with clean fuel
Some boats will fill the filter when the tank is full some wont. Generally it cant be relied on and the hand pump on the engine frequently wont plull fuel through an empty filter. I always carry a couple of gallons of fuel for that purpose. Some folks add an outboard squeeze bulb for filter priming.
I added valves at the bottom of the filter to flush out crap w/o taking the bowl off.
Jim: I also have valves to drain some and my filters fill after opening lines before I put the lids on. There should be some gaskets one for the lid, and one for the T handle, and I also change them each time I change a filter.
I think it has to do with the level of fuel vs the filter. If the filter is down lower than fuel then I would expect it to fill. that's why I cant depend on it self filling.
I thought from the last discussion on this that we were supposed to let the engine fuel pump fill the racor. Reason was u were taking a chance adding fuel that was not yet filtered????
For the new common rail or direct injections systems that is correct but some earlier ones wont prime the big filter. If they will that is always best for the reason you stated. Adding a priming pump has that additional benefit.
However, I looked at my racor more closely last week and notice that the fuel passage to the engine is at the top of the center rod. With the filter empty and a new cartridge installed pouring fuel in is better than I thought, as it must go thru the filter cartridge before going on to the engine. The turbine action is lost but filtering happens. Now I am less concerned about the fuel going into the filter if it was empty and a new cartridge is installed first before priming.
Additionally placing a new cartridge into a full filter even with dirty fuel also does some filtering as the cartridge is a snug fit around the center rod and fuel will likely be allowed to only go through the filter as well.
It seems a careful design.
Since you mention the crossover, if you have twin engines feeding off two tanks I suggest leaving the crossover closed unless there is a problem with one of the tanks & you close that one out of the system. Generally they will tend to draw down much more evenly that way.
When you pour out the contents of the old filter into a clear container, let that old diesel (or gas) settle for a bit then pour the upper layer good fuel ( usually almost all of it) through a cloth or coffeee filter or even a few layers of paper towels into the new filter to mostly pre-fill before installation. Even though that is not the full content of the old filter it may fill the new one until the media is completely saturated. Make sure to lube the new gasket and confirm that any gasket with the old one was definitely removed if it can separate from the element.
I don't think opening the drain at the bottom after element replacement will help purging at all(any air is at the top) & would likely have the opposite effect.
Thanks everyone for all the responses. We now have a three gallon portable diesel tank that rides nicely between two stringers in the aft bilge compartment. I need to ensure that this location is appropriate long term and make sure the tank is secured. My biggest concern was how to "prime" the new filter without a small diesel tank.
