It is time for an oil change on my Yanmar diesel engine. The only challenge is the oil filter which is mounted horizontally so that it leaks oil while I unscrew it. Is there a trick to prevent this?
I thought that I could drain the engine oil, and then if I could puncture an air access hole in the highest part of the filter, the oil in the filter could then drain into the engine so that less would spill.
Good or crazy idea? Any others?
Thanks.
Thanks.
