Chicken Wire Would Work . . .But
bobalong
I purchased some double foil faced, 1" sound shield that was advertised for use in engine compartments (auto & marine). Very sticky peel and stick adhesive on one side. My engine hatch was spotless when I stuck the insulation on last fall.
As I suspected would happen it has come loose.
Chicken wire would be a great way to hold it in place but would look rather g00fY. Screws with SS wire zig zagged would also hold but I don't particularly care for that. SS screws with plastic fender washers probably would work but I hate chancing an errant screw coming thru to the other side. (requires a LOT of screws & pilot holes)
Other than using an adhesive, (which is what the factory used, and took me forever to scrape and powerwash and re paint to get a good surface again) what have you used that worked OR used and didn't work.
In my motorhome I had a similar problem with the engine cover. Seemed eveything I tried would not stick. One day at HD I cound some plastic fasteners that were about a 1/2 inch on one end. The idea was you pushed them through what you were holding down to a hole on the other side. Same as they use for door panels now. Anyway, I jb welded them by the head to my engine cover and bought some large pliable plastic about 1/4" thick. Stuck the insulation on and cut 2" square with a hole in the middle and pressed them over the fasteners. It never fell off again. That was 6 years ago. My dad has the motorhome now and still no problem.
Not trying to be cute but... if the surface is being covered by the insulation, why does it need to be clean/look good? Seems to me you won't see it. When mine came loose on my last boat I used 3M spray adhesive to re-afix it and it worked well.
As a non-adhesive alternative, on my present boat the insulation is affixed with adhesive. But it's also supportd with strips of starboard that are drilled and screwed w/ cabinet washers.
You could try using 5200 to hold the existing foil in place. Get some clips to hold it until it drys. Use acetone to clean both sides unless either side is plastic.
Billy K.
There is an installation kit that allows you to epoxy or screw studs to the surface. Insulation is fitted over the posts and heads are pushed on over the posts to hold the insulation. Worked well.
Only way I got it to stick to the engine cover, particularly the underside of the cowling.
Hanging pins. West Marine Model #216874. $ 20.00.
I tried 3M spray adhesive (nasty stuff to use) and contact cement.
Heat and mean old Ms Gravity released both.
Good Luck!
Contact cement. Where there is little surface area for adhesion (such as floor joist), use mechanical fasteners. They actually make mechanical fasteners for this stuff, which are usually sold alongside the stuff, but you can just use screws with a wide fender washer too.
I used the pin kit but added 4 inch re-enforced aluminum tape around all the edges.
Installed on 4 hatches over the engine compartment.
Been on 8 years without a problem.
Was worth the effort, cut the engine noise down a bunch.
You should never count on adhesive alone to attach insulation in an engine compartment, especially on top of the engine. You need some sort of mechanical fasteners as well.
I used contact cement on my engine hatch. Six years now and it's still working fine. I used 3M Super 77 on the head liner about 4 years ago and no sags yet.
