Cleaning Inboard Props....
gregmercer
How do you guys go about cleaning or getting off a seasons worth of junk off your bronze/nibral props?
I tried using a random orbital sander with 220 grit paper but its going very sllooowww.
Is there a quicker way? Anyone use a wire wheel on a drill? Any other tricks?
You might try brushing on a quick application of muriatic acid, scrub with stiff brush(NOT wire) or scotch brite pad, then rinsing with fresh water. Wear eye & hand protection and don't get on trailer or concrete.
A: go swimming with a putty knife.
B: Find a convenient sandbar and do a little "dredging".
C: OOPS you're already hauled out? A plain old hammer works well, just smash 'em. The putty knife or a wire brush or the sander can handle what's left.
Greg, If you can remove the props, Bring them to a machine shop that can Glass Bead them.
Where are you located?
I'm guessing, but shouldn't Steam under pressure do the trick?
On one of the Science channel programs, they studied the 'glue' that Barnicals use to adhere.
They'd like to reproduce stuff like that for other uses.
The Barnical is a live animal and his little chemical feet go right into the pore's of whatever hes gonna live on.
I bet Steam under pressure would work because it causes the metal to open up enough to loosen the little guy's grip
I use a random orbital sander too but with 100 or so grit paper. Just move the sander along and don't stay in one place too long. Works great. Your 220 paper is too fine.
I use a Makita grinder with a wire wheel on it. Makes short work of the crud. Also use it to clean up the bare metal just before replacing zincs.
willie's swimming with a putty knife is the best and only solution. once on the hard, same thing, a putty knife will scrap them off. i woudn't worry about sanding, polishing, etc... once in the water as long as they are smooth, who cares what they look like !
Your welcome to come up and dive under my boat with a putty scraper in November! I can clear the ice chunks away before you surface. [:-shake]
Sandy has it down pat. Doesn't get easier than that !!
if the water is that cold, growth is the least of concerns :-)
Sorry John, I'm all booked up till summer. Pascal probably is, too.
The rougher the surface is that you leave behind, the easier it will be for the critters to grab hold of for next season. If you leave a polished finish you will have much less growth and with this much less cavitation and better economy. By using the muriatic acid,then a light polish,each season they get smoother and smoother.
I am in the process of using a 4 1/2 grinder with a "plastic scrubber." This is a 1/2 thick mesh looking pad that is basically sold as a paint remover. You can find them with the grinding wheels and pads. It is not leaving any scratch marks on the prop, but it cleanly removing all old crud and barnacles. This setup cleans very fast and leaves the nibral very bright.
The props I am cleaning are the spares for my boat and are on my work bench. When I haul the boat for the bottom washing I will remove the current props to clean them and put on these spare props.
G
