Cleaning Strainer Corrosion
mawyatt
I'm sure this has been answered before, sorry for the BW use.
My strainers and seacocks are beginning to corrode. I use CRC 656 & corrosion inhibit but still see some of the dreaded green corrosion on my brass/bronze fixtures. What is the best way to clean off this corrosion?
What Al said. The green protects the bronze from further corrosion.
But if you're anal, you could clean them with a mild acid solution and keep them coated with something like Boeshield. Or do like they do on large yachts, clean and then paint them with Awlgrip.
technically called "patina". It is the self protecting layer for copper compounds.
Toilet bowl cleaner does a great job. Used on packing gland when I replaced packing.
I'd refrain from using toilet bowl cleaner or other acids on a strainer screen... do it often enough and you won't have a screen. Heavier stuff like the seacocks should be OK.
IMO you're just making a lot of work for yourself.
Willie,
Sorry I wasn't clear...my bad. It's the container for the strainer, not the actual strainer screen which in my case is stainless steel.
Ah I have one of those. To me, green brass is "salty", and I like it that way. I've polished more than enough brass in my time.
Anything you use to clean it up will leave the bare shiny brass to tarnish all over again. The original corrosion inhibitor is probably your best approach, but as you've already found out it's not forever. You could of course paint or lacquer it but that's not forever either.
I'd grease/oil any moving parts (like the lid) and let the rest do it's thing.
"I'd refrain from using toilet bowl cleaner or other acids on a strainer screen... do it often enough and you won't have a screen."
As long as it's a mild acid solution, like toilet bowl cleaner and the screen is stainless steel, it's not really a problem.
Capt. Bill1, you beat me to the punch re the toilet bowl cleaner. It is not that caustic. Secondly, mawyatt changed post to state he was referring to the strainer container. Either way, neither w/b affected.
regardless of how you clean it spray with several coats of corrosion pro to keep it that way for a while.
