Cleaning the bilge
Redge
I recently purchased a '79 CC Corinthian and I was wondering what I could use to clean the bilge and help with the mildew smell. I did purchase some bilge cleaner but it was $40 a gallon and it smelled terrible. I was wondering about dish soap?
I have used small amounts of Pinesol for the smells.
Over time it works, if you use too much the smell can be overwhelming.
Mildew can be a challenge.
Abouttime
Are there products that should not be used on fiberglass?
I've use Spray-9 as it is great cleaner and kills mold and mildew. I've never used it in the bilge, but I don't see why it wouldn't work there. It also is supposed to leave a coating that resists the further formation of mildew. It definitely won't hurt the fiberglass so its worth a try.
use a citris degreaser or simple green but remember you MUST scrub it to get it clean.
bleach kills mildew and mold odors and will not hurt fibreglass. HOWEVER, it is very corrosive to metal parts and should not be left on fabrics, etc.
baking soda or vinegar will kill the mildew or mold by changing the pH of the area. baking soda is not corrosive. vinegar is somewhat acidic.
my preferred method for odor control is baking soda. make a thick paste of bs and water and put this in the affected area. let it sit for several hours, then thoroughly rinse and let dry.
good luck
i use dow scrubbing bubbles bathroom cleaner. cuts through most anything and it smells good.
Don't use any bleach in your bilge as it's a toxic gas around your batteries.
Simple Green and a scrub brush. A steam cleaner with the simple green will even take up quite a bit of any greasy grime.
Then keep it clean and dry and find the source of any water intrusion.
I'm trying to remember the name of the purple degreaser I used to clean my bilge - great stuff - cleaned and then painted with Interlux bilgekote - I'll try to look this weekend and I'll report back the name...drb2@gr5tmn memory...I don't think it smelled that great, but after it was painted there was no lingering odors.
I had one engine out. I was down on my hands, knees and chin, cleaning. I used plain ol' laundry soap powder.
Soon, I had one side lookin' good.
So I pulled the other engine out to get at the bilge under it.
Wow! It was so clean and white. Bright. I set to work changing the battery box's so I could clean under them next time. I moved the bilge pump too. It felt good to get that all straightend out. I waxed the bilges too.
I remember how neat that looked. I almost didnt want to put those nasty old engines back in there.
I buy 5gal pails of "Purple Power" for $20 available at Advance Auto Parts. I pour it full strength into a pump garden sprayer and spray down the whole bilge. I scrub where I can. I rinse the bilge and pump out.(Note to treehuggers - its biodegradeable)
I vacuum the excess with a shopvac equipped with an extra long hose. (electric motor is not in or near bilge so don't start on me)
What's wrong with electric motor in bilge?
I use a small wet/dry vac in bilge all the time.
Are we saying we can get sparks?
With most any electrical there can be an arc. To avoid any risk, buy equipment made for the mining industry. As for bleach, don't let the coasties see you draining that overboard. The coasties and the treehuggers will have a field day.
I use Tide laundry soap powder. It will cut the grease, get it lifted, then I collect it in five gallon pails, then ashore we go. There I run it through a condensate receiver to separate the oil and the water. At this point the water is safe to go down either the storm sewer or sanitary sewer. The oily waste is collected for future use.
El Sea
1976' Thompson 44
Suite 44
St Petersburg, Fl
