Cleaning Thru Hulls
So I noticed there are barnacles and other crap inside my thru hull under the boat.
Can I simply unscrew this from the bottom of the boat, clean it out and then re-attached it?
Are you talking about the screen cover over your thru hull inlet? Or up into the inlet "tube".
If it's the screen, just remove it, clean it and paint it. Just don't paint the holes shut.
If it's the tube, then scrape out the tube and use a small brush or roller cover to paint the inside of the tube. Of course you should clean and paint the inside of the tube if you are taking the screen off anyway.
Cover on the bottom of the boat.
Mine is a perko and I don't have a clean-out screen that I have seen on south bay strainers. I don't have the strainers. So I just have a bulged grill on the bottom of the boat. To remove it I will have to remove the screws holding it in place.
Yeah, then just remove the screws, clean and paint it. But be sure to clean up inside the thru hull too.
Do you just screw it back on?
Do you 5200 it?
Are those screws in the fibgerglass or into the other side of the metal? Do I need to use some lock tite or something make sure they don't vibrate out?
Thats kind of what I am looking for.
To make sure I don't mess it up!
Thanks!
Best not to use 3M5200 on anything on a boat except maybe the hull to deck joint.
What Solar said. Use 4200 on the screws and around the edge/lip of the cover. The screws most likely go right into the fiberglass.
Are you doing this with the boat in the water or out?
I wouldn't use 5200......if you plan to remove them next year to clean them. I would use just silicone.
I used 5200 on my Buck Algonqine strainers......to hold the frame in place......and just remove the screens each spring and clean them.
Don,
So if I want to add those strainers, I just add them using 5200?
There are no screws?
I was thinking of adding south bay strainers but was hesitatant to drill holes into the bottom of the boat. I really didn't have any issues with the scoops last year since I do have strainers inside the boat.
Dave.....there are 4 screws that hold the strainer to the hull......and 1 screw that holds the screen in place. Once the strainer is mounted.....all you need to do every spring is remove one screw.....slide out the screen.....clean it....slide it back in. EASY.......
OK. That type just screws into the hull. So be sure to bed the holes and screws.
If thats the case then removing this alot is gonna make the holes bigger, right? Wondering if I shouldn't hassle removing it.
Is there a easier way to clean inside a thru hull?
Perhaps from above cleaning the strainer with some ez on off.
It's no big deal to remove. And it shouldn't make the holes bigger. You really have no choice but to remove them to clean and paint them properly with fresh bottom paint.
regal uses a combination scoop/thru hull. the exterior screen side is part of the thru hull so you cannot remove that portion of it to clean as others have noted. the only thing you can do is get a small screw driver in the slots and clean out from the bottom. from the top side you can pull off the hose and clean it with a bottle brush from above.
Thats what I was thinking when I looked at it.
Removing the screws then won't gain me any access.
I think best bet will be as you describe.
Remove hose and clean and scrape as best I can.
Thanks.
I've seen that before from time to time. There is no proper way to clean and paint up inside it. Very stupid way for a manufacturer to do it.
Dave, I clean mine out from the outside with a narrow screwdriver without taking anything apart. On the engine and generator intakes I have south bay strainers but have the style you have on the air conditioner and washdown pump intake. It's a little bit of a pain but I seem to get them cleaned up enough that I don't have problems. Definitely more barnacles than usual this year though.
