Cleaning your holding tank
MrsRobinson
What is the best wat to clean out a holding tank? We pump out regularly and use Ordorlos, which works well however we would like to do a good clean out.
Do a couple/few cycles of fill w/ fresh, pump out, then add water and a little Dawn, to fill H/T about 25% or so.
Then go take a spin in da yot. Bounce over a few wakes and waves, and shake the tank up a bit. Slosh that solution around and it will degrease and break up much of what stays in the tank.
Then do the rinse - pump out thing a few times again. I must admit I never bothered to to this, and it seems to serve little useful purpose. I mean, ok, the tank is nice and clean and empty. Next trip out, it won't stay that way...
I suppose it might be a nice thing to do as a part of winterization.
One trick which is used in the RV industry is to put ice cubes in the holding tank, with a little water. The ice cubes will mechanically help to break up any debris on the bottom. They melt and then are pumped out. We do not put anything but human waste into the heads--no TP or other paper products--keep a small bag for these, and it will go a long way to preventing problems in the tanks. If you do put in TP, buy the cheapest you can find. Be sure it will "disolve" in water.
Bill's plan seems like it would work but like him, I never bothered with all that. I just make certain to rince the tank with F/W after each pump out. I have heard of folks dumping 25 lbs of ice cubes into the tank through the pump-out hose and then immediately going for a rough ride so the cubes would bounce around the tank and break-up and sludge before melting and a quick pump-out.
We did fill it up with fresh water after a pump out this weekend and then pumped it out again. That seemed to get rid of the slight odor problem we had. In 2 years we have never had an odor problem but we started smelling 'that holding tank smell' on each flush over the past few weeks.
When was the last time you changed the Sani-Gard filter? Your problem may lie there.
We have never changed it. My guess is this has never been replaced. This is our second season with the boat.
I have seen what looks like an in-line filter near the holding tank when I am doing work in the bilge. I will get some information off of it and check this out.
I don't know if BoatFix sells this but...
[:-bulb]
Greg,
I was having the same problem last year. What we do currently with the Regal is to insert a garden hose (lest the flames begin, it is designated and marked solely for this purpose) into the air vent thru hull and turn it on full blast while I'm pumping. The first time I did this was after a pumpout. I was shocked as to how much more crap (figurative and literal) came out of the tank. Now I just insert the hose and turn it on from the get go and don't turn off the pumpout station until the water coming out is as clear as the water going in. This all but eliminated the holding tank smell you referred to.
An RVer trick is to use water softener (Calgon or the like) in the tank as well after every pumpout. It serves to line the walls of the tank reducing adhesion, and for whatever reason, aids in the physical breakdown of solid waste.
GeeBee has a great post w/ pix detailing how he installed a "Tornado" holding tank flusher. It serves the same purpose as what I do, albeit more efficiently. They are available in RV centers. I'll be installing one this year.
I would recommend using the pumpout station at the Hopewell city dock at slack tide. It's free, it's brand new, and it could suck a tennis ball through a garden hose!
HTH
If you have a filter that's 2 years old it's probably the source of your problem. Try eliminating the filter first and see if that helps before you waste money on a new one. Many boats with properly maintained holding tanks and a free vent don't need a filter.
Sealand recommends using a cup of powdered laundry detergent that does not contain bleach. The company suggests using it once a month along with flushing water through the head by holding the pedal down for 60-90 seconds. Run the boat for awhile and then get a pump out. This is all we ever do and have had no problems for more than 10 years.
I've had good luck with powdered dishwasher soap. It emulsifies the crap out of it, and leaves it smelling fine.
Madge even lets her clients soak in it !
