Perhaps. But it's a grapple anchor. So unless it hangs up on something it's not really going to set. Even if you used, say, a little Bruce type, I bet you could break it out pretty easily.
While I can see the potential problems, my guess is in the real world it works fairly well.
In fact I'm thinking about setting one up for the heck of it. If I do I'll let you know how it goes.
Of course there is another way to do it. And that is where you have a long loop of line that you loop through the end of the anchor chain and set the anchor as a stern anchor. Then head into the beach trailing the looped line behind you like you would a normal stern anchor line. Unload the tender and then tie one loop of the line to the bow cleat. Then pull the tender out from the beach with the loose loop of the line. The shackle on the anchor chain acting as your pulley so to speak. Once you have the tender out about half the length of the line you tie the line to something on shore. When you want to retrieve the tender you just pull it back into the beach, load up and then go out and pick up your anchor.
Again, just like the other technique we are talking about there are situations where this can't be done. But in the right ones it works very well.
