Bill, the only routine maintenance that I know of at the present time, is to change out the joker valves (it has two) every few years. Beyond that, I really don't know of anything. It hasn't been on the market long enough for any problem areas to show up, and indicate any possible trends. (The Marine "Elegance" came out in October, 2008, not quite 2 years ago. We had been doing field testing on them for two years before that - so we have roughly 4 years of the product being in use, with no consistent failures of any kind.)
For the pressurized fresh water models, we are using a solenoid valve from a different company than we've been using through the years, so I haven't had any feedback on what their failure rate is. In fact, I'm not aware of any of them having failed as of yet. It probably wouldn't hurt to keep a spare on on hand as they aren't all that expensive, part # 221351 for 12 volt, factory price $24.00 - BoatFix price probably a little less.
For the raw water versions, the intake pump is remotely-mounted, and the diaphragm and internal wear parts of the pump should be replaced at about 5 year intervals. (Repair kit # DIAPUMPRK) The pumps are pretty much bulletproof, albeit a little noisy, and we haven't had any problems with them at all. The same raw water pump is also used for the SeaEra, Crown Head II, and Atlantes toilets, that flush with raw water.
