CO Alarm
In the know
Okay, start speculating.
I just got a call from Mrs. Know that she and Little Know returned to the marina courtesy of the port engine only.
The CO alarm went off shortly after they got underway. She said that upon inspection she saw a small leak (water drip) from one of the fiberglass Z tubes off the outboard riser.
After she docked, a closer inspection revealed a crack in the fiberglass piece.
How in the world could this piece crack at the end of June?
Title and thread edited - I sat next to the smart kids in chemistry so I could sleep through class.
CO2 = Carbon Dioxide, the bane of Al Gore.
CO = Carbon Monoxide, the bane of survival.
No big deal. Just trying to help the "lurkers" ... ;)
"How in the world could this piece crack at the end of June?" -- ITK
... because it's schedule was all filled up for May, and you had to wait?
Hopefully it will be a quick, affordable fix.
-edit-
Really, the most likely cause is ( imo ), "It just wore out". Can happen any time. Very convenient that the CO alarm alerted Mrs K to the hazard. ( And a happy thing, as well ). A reminder to us all to pay attention to "the bells and whistles".
Pardon my ignorance...but what the heck is a fiberglass Z tube and where is it on the riser? What would this have to do with the CO alarm going off?
Okay work with me on picturing this. Off the riser comes a section of about 6 inches of 4 inch hose. The hose connects to a fiberglass tube that is somewhat shaped like a "Z". Theis tube allows for a +/- 10 degree drop and then via another section of about 6 inches of hose, connects to a Y pipe.
If it is cracked, the exhaust is leaking into the engine bay - hence Carbon Monoxide.
Unless you had some sort of mechanical agitation I would just say stress fatigue. This can happen at anytime when you change temps on a certain piece repeatadly. I would bet if you looked at it real close you may see a flaw from original manufacture.
Hopefully it will be a cheap and easy repair for you
Glad to hear that Mrs Know and the little Knows are fine and did the right thing.
Mrs. Know is obviously a VERY smart lady and my hat is off to her. Very alert boating and excellent response!
I don't know how your boat is laid out, but I actually caught a mechanic standing on mine during an oil change and tune up. I requested that he cease and desist from such a practice for this very reason.
Originally posted by In the know
Would the boat happen to be a Sea Ray? I mean that would explain a lot...
Sir, no sir, not a Sea Ray.
Looked at it last night and the fix "should" be straight forward - back deck does have to come up though - ahh the joys.
Sounds like a crack in the fiberglass exhaust tubing.
I fixed mine with a small patch of glass and some resin.
1) Sand down the effected area, wet it out, apply glass mat, coat with resin.
2) Do step #1 again.
The issue of using flame retardant resin might come up. I don't think the heat that far down the exhaust system should be an issue.
1) Sand down the effected area, wet it out, apply glass mat, coat with resin. Let dry
3) enjoy the boating season.
