CO detector / Westerbeke compatibility?
David M
Xintex will not rebuild my CMD-2M detector on their $25 plan. They tell me it is out of production. In that it is 10 years old and has never gone off even when the portable home detector back up reads high, I am replacing it for safety sake.
I want to get this one that shuts the gennie off in the event of a CO alarm. However, I do not know if it is compatible with my gennie.
The following applies.
- 1999 Sea Ray 330 Dancer.
- 1999 Westerbeke gas generator model 4.5 KW BCGTC - 60Hz.
- Boat has remote starting in the cabin. The remote has 2 push button switches.
The left is labeled preheat which activates the choke and the fuel pump. The right is for off/run/start.
Will the CO detector I desire work with the setup I describe. I shall get better details when I get to the boat later today.
TIA.
Most generators use a +12 shut off solenoid that shuts off the fuel. If this device provides a +12 output when it alarms, it will work. Check your genny. If the shut off solenoid has only one wire, it most likely is +12 and it grounds thru the mount. The CO monitor will work.
Thanks Paul. I shall order it tonight. Do I have to go all the way to the gennie to do this or can I go to the off/on/start switch? The CO detector is literally less than a foot from the switch panel.
You can tie into the switch. It is electrically the same point. as long as it activates the solenoid, you can hook it up anywhere along the wire.
