Cockpit Air Conditioner
bobalong
Does anyone use or know someone who uses one of those portable A/C units in their cockpit. The kind that is on wheels and uses dryer vent hose to discharge heat from the condenser. Saw one on a 40-50' Chris, owner wasn't around for me to ask how it was working out for them.
Just curious.
Does the aftcockpit have a hardtop over it? I'm assuming you are talking about an enclosed aft cockpit?
If so on my bridge hardtop I use a Coleman low profile camper style AC/Heat pump 15,000BTU. It really has worked well going on it's 5th season. I don't like the portable units because they can slip and slid around and possibly be a hazard.
I have one of those portable a/c units at my house. They work but are pretty darn loud. Somewhere on BE there's at least one RO who uses one in his cabin to cool his boat. But as Bill said, they are on wheels so they'd really have to be secured when underway.
I have seen pictures of them. It seems there is only one hose to exhaust the hot air from the condensor. Where does it get the air going to the condesor? Does it just use room air; if so, then air from the outside will come into the cockpit. That would seem to be very inefficient.
It draws in the surrounding air to cool itself then expels it out the tube . So yes ur wasting conditioned air and drawing in outside air to take its place. I have a 16,000 btu cockpit a/c and its useless on a hot sunny day. ( I have a hard top )
Even with all 3 vents pointed at the helm its pretty pathetic. Boats need 30,000 btu to be a contender!
Rob is your hardtop insulated and both sides finshed? My unit does well but I also use 2 external 12VDC Bora fans to help it distribute the cool air or heat as needed.
Bill,
It's a Searay. So no insulation. ( yes both side are pretty looking ) They let power requirements trump usefulness ! I even had custom Blk out canvas made to completely cover my eisenglass. Still to no avail.
Rommer uses one in his cockpit and says it works great. And he does not have a hard top.
Rob, Mainship isn't any better than SeaRay but my hardtop was built by the guy who used to do the Cavalier Yacht custom glassworks.
Mine works quite well on all but the hottest days even then it keeps the humidity down. Without the 2 large BORA fans it wasn't cutting it.
Bill,
Send me a pics of the fans. Just curious as to how you set it up.
Thanx
Originally posted by Robski97
...I even had custom Blk out canvas made to completely cover my eisenglass. Still to no avail.
BLK = Black or block?
Is the canvas Black? If so is it absorbing heat?
A buddy has a 42 Carver ACMY. His cabin was a b!tch hot in the summer. He has a cover on his glass that resembles the dash protectors you use in your car. It's a silver like finish on the outside to reflect light and heat. Styrofoam sandwiched in between. It lowered the temp by 20 degrees in the salon.
Just a thought.
This was before I installed the BORA fans I will get that picture this weekend. This is the inside of the AC unit and my Wave WiFi high power EC unit. The previous picture has my old Engenius Router this was before I got the dream WiFi box.
Here is the boat with the original top and yucky Radar arch.
Here is a picture WalterV took of us in the Ocean running side by side with Dave and WalterV on their 3 hour tour trip from H*ll.
One more cloe up you can't really see much of the unit from the dock.
I had a custom thick Starboard air box made between the bottom of the hardtop (inside) and the AC unit. It has cut outs for the air to be disbursed. If you want more pictures let me know and I will take them this weekend when I go to the boat.
