Cockpit Air Conditioning
David M
There have been a lot of posts regarding how many BTU's for interior air and whether to use a dehumidifier or whether to let the A/C run while away from the boat for the week, etc. That got me to thinking (I know. A dangerous undertaking, but somebody has to do it) has anybody air conditioned the cockpit of their boat. It doesn't have to be a custom megayacht type of thing and it certainly should not be a window unit slid into a hole you cut in the transom. That's just too redneck. I am just curious to see if anybody has done it and if so, how. Pix would be nice.
You could either redirect an air hose from the cabin to the cockpit or place a splitter in the line. It would take a much larger AC unit to make this change.
Thought about doing too David, would like to read any responses.
Fred
I don;t understand, are you guys talking about air conditioning a cockpit enclosed in canvas and eisenglass? If so you'll need a hell of an AC unit and a healthy oversized generator.
IIRC, Regal has offered it as an option on the 4460. The 390 Cruisers has as well. I was just curious. The 330 Sea Ray had a cockpit heater and defroster as an option some years ago. They still may on the 340; I don't know. I suppose that could be converted to heat and A/C. Years ago I was at a restaurant in Baltimore's Little Italy. The deck was air conditioned!
A cool breeze beats stifling heat any day.
AC in the cocpit?
How about a 'cost-reduced' water temp cooler?
If you could pump some water out of the local media.
Run that through a Radiator of a sort. That should bring the Radiator to the local water temp.
Then blow some air across the radiator, direct the cool air toward the most important person.
Even if the water temp is up in the 80's, the air coming off the Radiator will be cooler than the ambient air.
This Radiator will be the crux of the matter.
Thin enough tubing to allow good convection.
Enough tubes to make a difference.
The kind of material that will withstand the chemicals in the water.
And a pump with a volumn large enough to satisfy.
OK David, there's your economic opportunity. Run with it!
My boss has a CY 430. He had two 12,000 btu A/C reverse cycle units installed in his cockpit.
The problem is you still need to have a way of providing shade to the cockpit otherwise it's like trying to cool your house with all the blinds/curtains opened. He's now looking at getting quotes for tinted eisling glass.
David, I was out fishing on a 64’ Spenser that had air conditioning vents blowing on the mezzanine seating. The Monteray birthed next to me has a cockpit mister to keep the fishermen cool. Jerry
MArine Air now has super compact units specifically for this purpose that do not require have the cockpit space for the installation ; )
"NEW! Dash Air
This new unit is a breakthrough in self-contained air conditioning systems. The horizontal compressor requires only 8" height for installation for location on the flybridge, cockpit, or any height critcal areas. Dash Air systems are reverse cycle and are available in these capacities: 16,000 BTU (115V/60Hz) or 13,000 (230V/50Hz)."
Big boat big bucks problem. Our 16000BTU salon system pulls 18 amps.
Just sit on the swim platform with your feet dangling in the water and a cold one in your hand!
Of course, only do this while anchored or at the dock with the engines turned OFF.
I put a/c on the bridge of my 38 and its enclosed with canvas. Feels real nice on a 98 degree day in Georgia! To cool open air you have to go to a misting system in the cockpit area it works pretty good.
To me it makes perfect sense. I've spent several hours exploring the options for our boat, a 2004 Real 4260 and figured out how to do it, moderately economically, but have decided against it. We have a hardtop which is HUGE and the idea was to mount an RV type rooftop AC unit and seal off the cockpit at the rear of the hardtop. I checked with the Regal factory and the engineers there assured me the roof was strong enough to support the weight.
What decided me against it was in figuring out how many hours I would actually use it. Sealing off a portion of the cockpit would be a pain and certainly cost a little space while underway and a minor hassle while docking. Since I do most of my cruising in the fall and winter I wouldn't need it then. My limited summer cruising would probably be more pleasant but I don't think enough to outweigh the hassle. Plus I spent some time on a 48' Searay Sundancer and while I really enjoyed the cockpit AC I didn't like the way the canvas blocked the swim platform view or the hassle of trying to remove stuff while docking.
Finally, the final decision was based on the fact that I don't seem to mind playing golf in this weather, why should I mind sitting behind the wheel, in the shade, with a fan on? I really don't. It would be nice to escape the patches of deer flies in the spring but I solved that by not going north in the spring.
Mike, Palm Coast, FL
I suspect that the intent was to air condition the cockpit of an express cruiser--I have a friend with a Tiara 44 which has the cockpit/helm air conditioned (not the fish fighting area) We air conditioned (RV 15,000 BTU roof type) on the flying bridge of a Symbol 42--insulated hard top, with clear vinly sides, and a plastic shower curtain over the stairs to the "sun deck"--it would bring the temp down 20 degrees.
Many small pilot house boats are using RV air conditioners--very practical--no water cooling problems, no worry about jelly fish or seaweed. Can run on the trailer or lift, and they are cheap--last as long as a marine unit--maybe longer and only cost $600 to replace.
Hi David,
We installed a 12K Marine Air (cool only) on our 89 Regal 280 back in 2003. I got a good deal on the cool only unit and didn't want to spend a fortune on a boat this age.. I believe this boat came from the factory with a 10K.. so we're a little bigger..
It was probably the best option we've added to our boat and it's a night/day difference.
We occasionally leave the cabin door open, and it's always cool down below for our girls.. this one likes to lay in the cockpit, but still keep cool with her nose just inside the door..
I can't say I blame her with all that hair.. [:-doggy]
Yeah, but how do I keep the cold one cold...ooops...never mind...figured it out....somebody grab me one from the cooler please!!!
Joe & Sheryl,
I can't for the life of me figure out how she knows where anything is through all that hair!!!
The mist system with a fan looks a good approach, esp when on fresh water.
Wonder how much water pressure it takes to mist?
Originally posted by KiDa
Joe & Sheryl,
Hi David,
Truth be known, I can't figure it out either... I don't think she can really see anything 1/2 the time.. especially at night..
She's actually pretty clumsy... but she is a very smart dog.. she makes me laugh a lot.
