Colored Hull - Yes or No
Though I have never been a fan of colored hulls, I am now looking seriously at a boat that has one. I know colored hulls have gotten better from the days of first ones in red and blue that used to fade. The boat I am looking at has a black hull.
1) My concerns are scratching, what color shows through?
2) Compounding, do swirl marks show up worse?
3) Fading of course?
4) Keeping it clean. White hulls show the dreaded black streaks, I guess a black hull wouldn't?
Thanks.
I like the colored hulls but here in the South I would worry about them getting hot when anchored. I swear I will never buy anything but a white vehicle from now on if at all possible. I don't know if boats are the same when it comes to heat but I don't see how they wouldn't be.
If it's gel coat, you'll be fighting oxidation, but small scratches can be buffed out. If it's the correct paint, it should be pretty durable, but you could get a scratch that goes through to the gel underneath. If you're in salt water, dark colors will show salt stains, but will hide the dreaded black streaks.
I had a beautiful burgundy Crownline and the work to maintain the color was intense but worth it at the time. A scratch would be pink in color; stark contrast to the burgundy so it would require immediate attention. I have gone to white on my current boat and I'll tell ya, it's a lot easier to remove the black streaks from the white than trying to keep up a nice colored gelcoat.
Good luck
Colored hulls = no no no (just my opinion based on maintenance and potentially lower resale value due to aging, fading, etc.). I wouldn't even consider one.
I personally like the look of colored hulls, but boats are enough maintenance as it is, why add another element? You'll either be paying someone to take care of it for you (will get expensive if done right) or you'll be doing it yourself and cursing for making the decision. Even the boat mag's tell you to stay away from colored hulls.
The colored hulls are beautiful, but I would consider that, once the "color fad" fades, you'll be left with a boat that looks it's age just because of the colored hull. In a sense, my 20 year old Carver with a colored stripe, actually looks less old because of the new color fad.
On the color itself, my dark blue stripe (so dark it looks black) still looks really good and shines as deep as a new boat.
I've fallen in love with the new Cruisers Yachts 360 Express, and would probably order it in black...it just looks sharp!!!
I LOVE the looks of colored hulls. Every person I know who has one, regrets their decision to go with a dark hull. No one has mentioned heat (even though we are approaching the third hottest summer with 37+ days of 100+ degree heat). They're just talking about the water spots. We have really nice and clean water on our lake, but it is fairly hard water and it spots easily and quickly.
I think they can make the boat look aged very quickly if they are not maintained---whereas with a white hull, you can get away with more flaws. This is not even talking about rubs, scratches, etc.
Paul
I agree........colored hulls do look nicer then plain white........but at a price.
I'll never, never again have colored gel coat. paint maybe but never gel coat fading is terrible. Maybe is covered slips and inside winter storage but :(
NO NO NO!!!!!!!!!!!!!!!!!!!!!!
I WILL NEVER GET A COLORED HULL AGAIN !!!!
EVER!!!!!!!!!!!!!!!!!!!!!!!!
You are going to be fighting that color for the life of the boat. Have you ever tried to keep a black car looking good, its a never ending job. Same thing here. Every blemish, scratch and swirl will show up that much more on black. It does look nice when it looks new, but it doesn't look new for long. If you shrink wrap your boat for the winter, then you will almost have to compound every spring to remove the very visible scratches on the hull from the rim of the shrunken plastic.
I have turned down boats with dark hulls simply because I think I would wear the gelcoat away trying to keep it blemish free.
Shel
Hmmm, good arguements.
I have a good deal brewing on a colored hull.
How do you tell if its paint or gelcoat?
It is a a 2005 Regal 3880 if that helps.
THERE IT IS...............From a colored hull man himself.
Colored gelcoat.
Depends on the color. Fighting Lady yellow would be a good choice for a convertible or center console.
I have a seafoam colored center console and have no problems with fading or unsightly scratches. Scratches are there but they don't stick out, barely noticible unless you look closely.
If you go dark, you are asking for trouble. you see every scratch and every water spot. Not worth the trouble.
There was a brand new black Cruisers at my dock last year, the fenders and docklines were already scratching the gel cote withing 2 months, looked pretty bad.
NO!!! Stick with white, the color boats should be. ;-)
Colored gelcoat.
John,
Isn't yours colored? How is it holding up?
Most regal 3880's seem to be colored, white is rare, as is diesel.
