Just to Be Safe:
I would pump out all of the old fuel, take the plugs out, pour some Marvel Mystery Oil in each cylinder, wait a few hours and hand turn the engine a little at a time to make sure it's nice and free. Check the oil, change all the fuel filters, replace the plugs, put in fresh fuel, and start it up.
Let it run up to temperature, then drain the oil, change the oil & filter, and it should be good to go if it was put away running.
You can skip any, or all, of the steps if you want. It might start and run fine for you. But why take a chance? You don't want to be chasing bad fuel problems, crack a dry piston ring, or score a cylinder wall with a dry start after 6 years if you really don't have to.
