- Sep 16, 2003
- 12212
- 12,183
More pictures uploaded to the album linked above.
Got two new battery chargers in. I picked promariners as I ve always had good luck with them and the ProNautic are pretty compact. I decided to install them out of the engine rooms so that they don't sit in there cooking and in a location where their displays can easily be seen instead of having to add remotes. They re under th helm / above the companion way. That's close to the batteries. I ll eventually add some wood trim around them.
Final two bilge pumps are going in. I already have two in (aft and forward). These two are going in th ERs. Again using 3700s mounted on starboard brackets wit high water switch above the pump. I can't believe it took me that long to come up with these starboard brackets... All these years Dealing with hard to reach screws in the bottom of the bilge!! Much easier this way as th brackets aware screwed high on bulkheads, stringers or even floors. SErvicing any component like the float switches only requires pulling th screws and th whole thing comes off.
In one of th last pictures, the pump panel instwlled at the helm can be seen.
