Compression Test Results in!!! Please Help
dsmboosted
Ok, I had a boat I am looking at buying compression tested (I have not had the sea trial yet)...note the boat has been sitting all winter. The boat is a 1986 Sea Ray 300 Weekender with 2 inboard engines.
The numbers on engine 1 are (1900 hours):
cyl 1: 140 cyl 2: 140 cyl 3: 140 cyl 4:140
**cyl 5: 90 cyl 6: 120 cyl 7: 140 cyl 8: 125
**They squirted some oil in cyl 5 and the pressure did not come up on the wet test.
Engine 2 (1908 hours):
cyl 5: 130 cyl 6: 130 cyl 7: 120 cyl 8: 140
The mechanic said 2 things:
1) He thinks it needs new heads on engine 1 because of the low hours. He said if we redo the heads it might pull oil through the rings because it will be creating more pressure. Any thoughts? Is it dangerous to just do the heads and not re-ring?
2) He also said the valve above cylinder 5 on engine 1 may be stuck due to sitting all summer. He offered to do a compression test for free after the sea trial, he thinks it MAY just need to run.
Please let me know what you guys think...
a sticky valve or collapsed lifter are two of many possibilities. I wouldent run it until I removed the cover and worked that valve with a little oil but thats me. It really could be that simple. Or it could be wiped cam or bad head gasket or stuck rusty ring. I never suscribed to the top end causing ring problems theory.
In order:
you free the valve
watch the cam lift
then pull the head if those are ok
Engine #1, 5 cylinder has a suspect exhaust valve. If it was a worn piston ring, the pressure would have come up with oil being added.
Everything else looks fairly nominal.
Inconclusive...add some Chevron Techron to the fuel system and give the engines a good run.
Offer to buy it subject to a sea trial and another compression test after the sea trial. If something turns up not to your liking you can then make a lower offer or walk away from the deal.Nobody should expect you to buy a pig in a poke.
So if we assume it was a bad exhaust valve, and rebuilt the heads... do the compression numbers look solid enough to assume the engine MAY have 500-1000 hours left if everything is maintained properly?
What are acceptable compression numbers?
Don't assume anything just yet...take it for a sea trial and put it thru her paces. Recheck compression.
The numbers are mid range indicating some wear..but certainly still within spec. I've got a seven year old MerCruiser 350 Mag that's turning 190-180 thru the cylinders.
possibly
How did the plugs look???
no reason to pull heads until cam, sticky valve and flat lifter are ruled out.
consistancy is more important than absolute numbers. with a storage engine they will likly be different, higher and possible more even, after some running
You don't say if the engines are original. Don't laugh I have a friend with a 1988 Sundancer with twin 5.7's that are original. The boat your asking about has been stored all winter? If that's the case I'd go over the whole boat then sea trial it and after that I'd do a compression test. While I agree that it sounds like a valve, it's not all that suprising considering the age of the engine. If the boat is what you want otherwise make an offer figuring that you'll be putting in an engine when this one needs replacing.
my whole deal is I am so new at this and I dont really know what Im talking about...to tell you the truth. Its my first boat.
I just want something that is going to work. I got a quote to replace the heads for $1600..which is not bad. I am getting the boat for $10,000 and otherwise the boat is in great condition. I just need to know if there is a good possibility,considering the compression numbers, that the bottom end will hold up after the vales are redone.
Originally posted by pdecat
possibly
You say with a storage engine, higher and posibly more...do you mean the compression number may be higher after we do the sea trial??
dsm...don't fret too much yet. Do as the others have said. We are buying a '87 pending surveys and its engines are original. The boat is up in Mi in heated storage. I am having a regular survey done next week and if all's well they will remove the boat from storage and into the shop to do a leak-downcompression test. They will run both engines and get them loosened and warmed up from the long winter being idle then they will to the compression test. I’ll sea trail sometime in May.
Good luck
Niles
Really sounds to me like a valve problem - had the same readings on my Campion Merc140. (I assume not OHC) It's pretty easy to pull the head - rent a torque wrench and do it yourself: pull the head and take it to a head rebuilder. 1/2 day's work (if you don't know what you're doing) and $300 and yer done!
druid
you are doing fine. Realize that the hours are big, the boat is old and the price low. The seller know this as well. The risk is that the rings and or bores are shot, at least in that one bad cylinder. Then the expense becomes really serious unless you are a wrench type. At that price you could do well or spend very big bucks to replace an engine.
I suggest that you write a sales contract that allows the valve tests above and then a sea trial and if the compression is still low the seller agrees to a sale contract subject to the head removal. The sale contingent on the results revealing that the valve is the problem and not the rings or bore. Who pays for the head removal is negotiable. I would offer to split the cost as evidence of good faith but that is absolutely not required.
The idea is you agree to buy if it is only in the head but the sale is cancelled or price renegotiated if more is involved.
even if you correct the problems with these engines, you have to count on a repower within a very short period of time as these are very high time engines. But hey, a re-power isn't that big a deal if the price on the boat is right. On the other hand, there are tons of boats out there and with this being your first, why not find one that you won't be pouring a lot of money into?
When you say a ashort period of time for a repower...what can I expect?
What is factory compression numbers on a new engine?
You might get thru this season and maybe not, but the engines will always be suspect. Unless you are really mechanically inclined, or have lots of money, i'd pass on this boat. Do you want to spend your time and money on the water or on the hard. 180 to 190 on new engines.
180 to 190 is the stock numbers??? I had another guy tell me new engines were 150...can anyone second either #?
180-190 is good numbers. Seen those type of readings hundreds of times.
Little side note: I am rebuilding my 350 as we speak. The "low" cylinder was 145.
