Computer Help, SD and Chip Needed for Garmin
Crossroads
I have a Garmin 540. I need to do a software update with my Garmin. The folks at Garmin can sell me an update SD chip or they say I can download it but I need an SD card with at least 256 MB and an SD reader. OK, what do I buy because I'm sure I can find a use for the reader and SD card. I have a Dell computer running Vista and I'm not so certain I can go down to Walmart and pick out what I need. Any help from the computer heads would be appreciated. I live in a small town we don't have a Best Buy, Circuit City, or such.
If you don't want to do this, Garmin has a program where they send you the update on an SD card. When you return it they refund the $50 to your credit card. Garmin posts frequent updates, though.
If you have a Vista-capable Dell, it must be a late-model computer. You many already have an SD card reader built-in. Is it a laptop or desktop? Look for a little slot that says SD, or MMC, or memory reader. If you have that you're set. Just pick up an SD card. They are cheap these days - go for a 512 or even bigger.
I have a desktop Inspiron 530S. It only has two USB ports on the front, no card reader.
Ok, then you need a card reader like you thought.
You need a card reader similar to this:
It plugs into an open USB port. Just insert your new SD memory card, which looks like this:
Vista should automatically recognize everything, and the card will look like a hard driver on your PC.
Thanks for the help, I should make a better effort at keeping up with changing/advancing technology. Seems keeping up with all the new wines on the market overloads my active memory.
UPDATE, I managed to get a cheap SD card reader and a 1 meg SD card. Now the software update I downloaded from Garmin has been loaded on my boat. Have a nice weekend.
