Connections to secondary starter relay.
Chrisv
I am replacing the secondary starter relay which is located near the red circuit breaker. The two small wires appear to be attached with some sort of fitting that slides over a post and than there is a bunch of rubber sealant of some type holding them on. In my manual they don't specify any special type of connection. Can I just use a crimp on fitting that will bolt on the post? If I do have to use the rubber stuff what is it?
I love the little suprises you get while working on a boat.
