Remember to wash out all the stuff you got off the battery. Its still active and will eat the rest of any metal it comes in contact with.
The cell next to the postitive pole always seems to be the one getting low on water.
Why the Gasses collect around the Positive pole is a week's lecture in a science class.
Checking the specific gravity is easy with one of those little glass dubers you can also get from an auto-parts store. It'l tell you if you actually have a weak cell or if your charging method is just too vigorus or out of limits.
rduhon, in a class with the Chebby guy from the land of smoke n' mirrors itself.
He was lecturing on the new EFI's and he mentioned one little tidbit almost every guy in the class ignored.
His point, on cleaning the battery terminals, was to use the big Reamer tool, and specifically NOT use that litle conventional method everybody else has been using for years.
His logic was that brush leaves little furrows (like a plowed field) between scratches and the stuff on top the furrow actually promotes more corrosion while you aint looking.
I didnt abandon my little stainless combination brush tool though.
