Having problems with water pump and I'm addressing that. Here's the question. When we follwed line to water supply which is from a fresh water tank. We also found a check valve in the line. It's after market check valve purchased from ACE hardware, sticker was still on it. Is it even needed? I'm assuming it was put in to keep water in the line so the pump wouldn't have to work so hard?
Suggestion or Ideas?
